Case 400 belt pulley
I feel, not too rare, if you're talking about the Racine 400. Both of mine, a '55 and a '56, have them. The later smaller 400s had one driven off the pto in the rear, probably quite a bit more uncommon.
Pic is of a later one.
<image src="http://forums.yesterdaystractors.com/photos/mvphoto12021.jpg"/>
I'm not sure about rarity on the big 400's (1955-1957). I added one to my 55 and my 57 had one on it. Adding one once you have located a drive is pretty easy. The hardest part is setting the backlash on the bevel gears in the transmission. If you do add one make sure that you get the shims that go with it to adjust the backlash on the gears.
Eli
