I am working on my 1950 case vac and I need HELP. The tractor will not stay running. It runs fairly OK when it starts up and shortly after it just suddenly quits,I can't catch it with the choke and keep it going. it is as if I turned the switch off.it seems to get worse the longer you run it. I have replaced the points and condenser, rotor, cap, wires,plugs,coil "internally regulated" and rebuilt the carburetor. With cylinder 1 at TDC my rotor is pointing at number 1 on the cap but my timing mark isn't in the sight hole. Being that it runs and the rotor is pointing to #1 I don't see that being the problem or is it. Any help would be greatly appreciated
