I have a 69' Case 480Ck with the 4 cylinder diesel. I removed the injection pump, replaced the shaft seals and top cover gasket. Put the pump back on, bled the lines, getting fuel to the injectors but will not start. I never turned the motor while it was off and I aligned the dots on the shaft and in the pump key way.
My brother in law is a diesel mechanic at an excavation company and he's says it sounds out of time.
I do not understand how this could be? I have no idea if anyone was in this machine before me so the only thing I didn't check was if the dots were line up with pump shaft and key slot when I took if off.
If it was not turned over and nothing moved on the machine, is timing being out even possible?
