S J P
Good morning, my 800 COM has the COM fluid getting into the rear end. As the tractor gets very limited use how big of a problem is this or can I just continue to add COM fluid and drain the rear end?
Thanks Steve
Major repair. 2 areas of concern & both require removing the Converter. The Converter output shaft has a bushing pressed in that carries the PTO shaft & that bushing wears, and behind that, in the range input shaft are 2 seals, back to back that separate the fluids that need replacing.
