TractorLinks.com
Show Parts for Model:
New 700b Guy
PartsMan79
02-12-2018 10:11:44
Hi all. New guy here from Oklahoma just pulled Grandpa's old case out of the pasture. I was the last one to drive her but that was over twenty years ago. Wish me luck!
Am I crazy to think I can lube the pistons by pouring down the exhaust manifold with the decompression valve open?
PartsMan79
03-02-2018 06:57:04
 Re: New 700b Guy in reply to PartsMan79, 02-12-2018 10:11:44
I a glad that I did NOT pour oil down the exhaust manifold.
I did remove the manifold and vacuum out a couple handfuls of dirt/rust before squirting Deep Creep down the exhaust valves.
I have got my fingers crossed that she will free up.
kevinthefixer
02-27-2018 18:14:46
May well have had the wrong oil too. Recommend you put in a quart of diesel fuel with the new oil, warm the engine up and let it run for half or an hour, then change it again.
PartsMan79
02-27-2018 07:41:39
Pulled the valve covers last night. That THICK oil is coating everything. I am happy about that. However I figured out why the oil was so thick. There was no oil filter in the canister.
PartsMan79
02-26-2018 13:59:01
Finally drained the engine oil today. NO WATER!!
Just thick black oil.
PartsMan79
02-17-2018 13:04:35
Pic of loading her on the trailer.
Kind of tricky with three flat tires.
PartsMan79
02-17-2018 13:00:45
We got the old tractor hauled to my work so I can get started on her.
The serial number plate says it is a 702b. Is this an orchard model?
I do not remember it ever having full fenders. Grandpa used it to grow wheat.
Ande
02-15-2018 19:36:19
Welcome! Glad you joined us, we look forward to seeing more of you and the "700B"
Ande
02-15-2018 19:42:04
 Re: New 700b Guy in reply to Ande, 02-15-2018 19:36:19
Crack your engine oil plug a little ways and see if any engine coolant has leaked past the sleeves from sitting.
PartsMan79
02-13-2018 07:08:20
Yes it is a Diesel. Definitely keeping it. I might be disowned if I sold Grandpa's tractor :).
Going to do our best to get it fixed up.
kevinthefixer
02-13-2018 05:07:55
Eyes getting worse daily. Maybe you can see that as an injection pump; I see a blob. Sorry!
Case addict
02-12-2018 20:57:55
Pretty nice tractor! Are you intending to keep it and get it running again?
casecollectorsc
02-12-2018 18:06:13
Pull the cap off the end of the rack in the injection pump to make sure it isn't stuck. Top front edge of the pump...3/4 wrench fits the two flat sides.
kevinthefixer
02-12-2018 17:59:13
Seems much more certain to simply unscrew the plugs. It is a gasser, right?
olgentdc
02-12-2018 18:21:40
 Re: New 700b Guy in reply to kevinthefixer, 02-12-2018 17:59:13
the injector pump can be seen on the right, kevin ,it is silver. 700 guy ,as long water is kept out of exhaust,you should be good to go , drain the pan ,check for water
