TractorLinks.com
Show Parts for Model:
Re: Info and opinion on older Case
Bruce from Can.
02-09-2018 11:47:09
This looks like a 530, loader is blocking my view , so I can't tell if it is gas or diesel. I had a 530 Triple Range , diesel and really liked the tractor. These tractors came in both Case-O-Matic , and dry clutch. My tractor was the dry clutch. The one problem I did have was the seal between the torque tube and the rear end let hyduralic fluid leek into the rear end, which would over fill the rear end and leek out of the axle. I wouldn't let this scare me away from a 530 Case tractor , but it is some thing to look for, we changed the seal and solved the leek. Nice loader tractor, better if it has power steering. If it is all good to go , should be worth $2,500 - $3,500.00 Take a good look at the tires, if the tires look really cracked , and are in poor shape, the tires could cost $500-$800.00 each to replace, so the rear rubber needs to be good !
Adirondack case guy
02-09-2018 16:34:22
 Re: Info and opinion on older Case in reply to Bruce from Can., 02-09-2018 11:47:09
Bruce,Not a 530. The 530s fuel tank were part of the hood profile. The fuel tank on this one is inside the hood panels. Makes it a 400B with the lever under the RH of steering wheel.
Loren
Bruce from Can.
02-09-2018 18:30:15
 Re: Info and opinion on older Case in reply to Adirondack case guy, 02-09-2018 16:34:22
You have a very sharp eye, I didn't even notice the fuel tank was like the tank on my old 430 had been, under the tin. So would this tractor be as old as 1960 ?
Adirondack case guy
02-10-2018 06:36:41
 Re: Info and opinion on older Case in reply to Bruce from Can., 02-09-2018 18:30:15
It would be a 58-59.
Loren
