TractorLinks.com
Show Parts for Model:
Re: Head Gasket Seeping.
moll
02-08-2018 14:36:05
Always better to torque em all the same, in sequence. If you don't have access to a manual, start in the center and circle out.
L.Fure
02-08-2018 16:12:07
 Re: Head Gasket Seeping. in reply to moll, 02-08-2018 14:36:05
Does the hood have to come off to get the valve cover off?
Adirondack case guy
02-09-2018 06:25:42
 Re: Head Gasket Seeping. in reply to L.Fure, 02-08-2018 16:12:07
Just open the cover on the hood, and work through there. It covers everything from the radiator to the dash. If the gasket is weeping, you may as well figure on replacing it. If you replace the gasket, you would be further ahead to remove the whole hood.
Loren
oldproudvet
02-08-2018 15:26:23
Be sure on a re-torque, to loosen the bolt to be tightened first, a quarter turn or so, then bring it up to spec. The break away force needed to start the bolt turning is usually more than the final torque
tomturkey
02-08-2018 18:46:50
 Re: Head Gasket Seeping. in reply to oldproudvet, 02-08-2018 15:26:23
thank you oldproudvet...I think at one time I knew about breaking loose then retorqueing. Thanks for bringing it up.I may have learned something new today. gobble
