Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
lift arm repair for ACG
george md
02-06-2018 21:14:46
Loren,
A month or so ago you were discussing eagle hitch arm repair , I just finished several . I replaced the tubes with heavier stock and made thicker and longer bushings as well as new pins. Here is a before and after , the link will take you to all the steps.
george
http://photos.imageevent.com/gmachine/caserepairs/repairsteps/websize/Imported%20from%20qu100_5274_jpgqu.jpg
L.Fure
02-07-2018 11:11:30
 Re: lift arm repair for ACG in reply to george md, 02-06-2018 21:14:46
I have one of those hitches. I like to use it for hooking up to my utility trailer. I also have a homemade tool bar the previous owner of one of my 400s made. It extended past the right side eagle hitch arm. He was missing his right eye and he said the hitch helped with pulling a gravity wagon up to an elevator drag. I never seen it used, because when I was around I was the one pulling in the loads. For a farmer who had been operating tractors since the cross engine days, he couldn't back a wagon worth a darn. A lot of his tractors had homemade hitches on the front of them. He always marveled at how quickly I could back a wagon into a spot.
Adirondack case guy
02-07-2018 06:36:05
George, looks real good. Around here when the tube got pulled off the arm, a piece of strap iron got bent and welded around the tub and up on the arm top and bottom. Farmer fix. HeHe.
I have to repair the RH lift link on my 431T. The threads have warn in both halves, and don't hold. I had to wrap a light chain through the clevis and yoke to get through the summer.
Loren
L.Fure
02-07-2018 06:32:19
I think mine measured 26" when I measured it. I was thinking of switching them around. I better do some measuring to make sure that would be the answer to my problem.
L.Fure
02-07-2018 03:56:45
I need a little more play in the lift arms on my 300. I have a heck of a time getting anything mounted on them. It ends up involving a big hammer before I get an implement wedged between the lift arms. These are implements I have been using for years on other tractors with eagle hitch.
John Saeli
02-07-2018 05:52:32
 Re: lift arm repair for ACG in reply to L.Fure, 02-07-2018 03:56:45
If I had to guess, your arms got pulled in toward each other when someone put a chain thru them & pulled. Should measure 28" centers. I've corrected several with a porta power & torch.
Adirondack case guy
02-07-2018 06:39:45
 Re: lift arm repair for ACG in reply to John Saeli, 02-07-2018 05:52:32
Yup, that happened quit a lot didn't it John. Especially on those lighter arms.
Loren
John Saeli
02-07-2018 09:59:12
 Re: lift arm repair for ACG in reply to Adirondack case guy, 02-07-2018 06:39:45
Yes, foolish thing to do. This is the answer!!
Case Nutty 1660
02-08-2018 03:04:39
 Re: lift arm repair for ACG in reply to John Saeli, 02-07-2018 09:59:12
I hook to the drawbar not the EH arms,, unless I have my hitch on the arms,, I wish I had one of those as well but I will use the homemade one
cnt
Adirondack case guy
02-07-2018 15:52:39
Yes, I now have 2 of those. Factory built.
Loren
george md
02-06-2018 21:18:25
Before photo didn't make it , it is in the link.
george
