Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
NUTZ
Dave Sherburne, NY
02-06-2018 07:58:27
I was out plowing snow with a Case 444 yesterday and just about 3/4 of the way through, A BIG BANG and she was all done. OOPs, I think she through a rod. I can reach in and spin the fan very easily. I went out and got the Power King with a plow and luckily the old girl started so I could finish the driveway. A friend of mine showed up and we pushed the Case into the shop. Had to go to the doctor so didn't get a chance to look it over. Later today when I get back from a stress test at Basset Hosp I may get a chance to look it over. OR maybe I'll work on the Case 444 that I'm putting a snowblower on. Still gotta put some weights and chains on it. I prefer to use the Case tractors for snow removal because of all the forward and back when plowing. The PK is gear drive. I have a Kohler from an old Ford GT but I think it's a 12 Hsp. Supposed to be 8 inches of snow coming tomorrow. If all else fails I can call my grandson and give him a good laugh.
Dave Sherburne, NY
02-07-2018 15:27:20
 Re: NUTZ in reply to Dave Sherburne, NY, 02-06-2018 07:58:27
This morning I went out and plowed snow with the Power King then I worked on getting the other Case 444 with a $400 rebuild on the engine, ready to blow snow. After lunch at 2pm I went out with the Case and blew snow for about an hour. I used it on the tractor that blew up and it worked great. It is working great again this year. I cleaned the driveway and also made a path so I could get the truck out of the backside of the garage. Then I started on the one that threw a rod. Didn't get very far but I took off the fuel pump and looked through the hole and the rod is no longer connected to the crank. We got a total of about 7 inches of snow today.
Dave Sherburne, NY
02-07-2018 11:09:15
The Stress test went very well. As far as the snow removal goes, I now have the Power King with the blade on it I used this morning, we had about 5" at 9AM. Since I plowed this morning, I have also got the weights , chains and snowblower on a different Case, and am getting ready to give it a try this afternoon. I'll probably get into the bad engine a little this afternoon.
rfdmn
02-07-2018 06:20:55
Hope your stress test went well!! I would think the engine problem would be all the stress you would need.
L.Fure
02-06-2018 18:02:51
A lot of people remove those balance weights for just that reason. They are known to fragment and ruin a good engine.
Dave should go to this site for help.
http://casecoltingersoll.com/forum.php
He should also call Bill at Barneveld Implement for any parts he might need. Or another engine. They also have tractors they can get a used engine off of if he wants to go that route.
http://www.barneveldimplement.com/parts---accessories.html
mEl
02-06-2018 16:17:20
L. Fure, you are right, the Case block has the pump mounting bolt pattern and a locating ring cast into the block, looks like he did better than I when mine blew, I knew something wasn't right when I saw the starter hanging from its wire down at the deck, made a mess on my deck as it kept running with the side of the engine blown out with a 6 inch hole, I believe it threw a balance weight. Hab d to shut it off with the switch!!
L.Fure
02-06-2018 09:52:08
Anytime is never a good time to have a breakdown. I don't think your Ford Kohler will work in the case. You will have to have one designed for the 444. Are you sure the rod broke?
