Shannon1973
New User
Okay guys here's a good one for you
Call my uncle decides to restore my grandfather's 1946 case VAC and in doing so he did not do some things correct so the tractor runs and it drives does not smoke he did not restore the internal compartments basically all he did was restore the exterior it has been converted from 6 to 12 volts the problem is when I go to actually drive the tractor I could drive in about 35 40 ft and it acts like it's running out of gas the throttle rod in the center of the carburetor is extremely loose and the spring on the right side going to the governor where the foot throttle is is also very weak I don't know if it needs to be tighter to pull more tension on that Governor lever any help would be tremendously appreciated
