Dave8N in Pa
A friend of mine has a 900 to run his feed grinder. It has started making a humming noise. I went up to listen to it last night. It hadn't been run in a week. When he started it up it took about a minute or two till the noise began. It's a low pitched hum. It doesn't change with the clutch in or out. We ran the grinder for a few minutes and nothing changed. We are going to run a batch of feed today and see how it goes. I don't know these tractors but it seems to me it could be hyd. pump. I will check fluids today. Is the hyd. fluid and trans. the same or are they separate? Any suggestions what else to look for? Thanks Dave.
