Patsdeere
Curious what a LA lp tank carries in terms of gallons. Also, if you aren't working it, just driving, how long will a tank last?
Thanks.
On the birth plate it has a W C # witch is gallons it holds. Usage depends on hard it is being worked. Will have more power on liquid than vapor.
Looked at the LA propane tank I have in my shop. Could not find the gallons on it. Will look further later today.
Richard in NW SC
If you are just playing with the tractor, it could last for weeks. I believe the tank holds 42 or so gallons. If you were plowing in descent ground it would run about 4 hours. Hard pulling, even less.
Just putzing around though, a tank would probably last quite some time. Hard to say because you don't know how many hours it would be. Possibly on a tractor drive for instance, it would probably last all day. Bob
