970 Case won't move update
JBobbe
About a week ago I posted about my 970 Case wouldn't move. Almost 3 weeks of subzero weather. Today was the second day of temps above 32 with it close to 40. I set my torpedo heater to shoot under the transmission for an hour with tarps around to keep heat in. Started it up. Everything normal and working. Transmission pressure gauge on the high end of normal. Thanks for all the help. Now to figure out how to keep ice from forming and apparently clogging the hydraulic intake tube again.
What will Red Heat do to the Clutch Disks in the tractor? Will the alcohol effect them in any way?
I lost every fiber disk in my 1370 because of using oil that i was told was correct for the tractor when it was not. I turned a Cherry 1370 into a nightmare because i listened to a local oil company claim their oil was correct for my tractor.
Warm the hyd up install hose in the aux valve so aux oil will hot drive up down road at the Dealership get the oil hot we add about 5 gal diesel fuel to help the breakdown the bad oil then drain oil let set for a day change filters used a good hyd oil we never had no problem using diesel fuel to break that bad hyd oil
