fixerupper
I did some work on an SC that was converted to 12 volts. It has a Case mag. The starter really spins it over. When it's warm it pops right off. When the temp is below 30 or so it will tend to flood but eventually will start. When the temp is in the 10 degree range it's a no go, cranks but won't start. After it starts it purrs along better than most SC's Ive been around.
I just delivered it to the customer today so it's gone now, but I just got to thinking, do you suppose the starter spins it so fast the impulse isn't engaging? Have any of you seen this happen?
