1938-39 Case R wheels Info.
I posted a set of wheels on photo adds parts. I was curious if these wheels will fit any other case tractor beside a Case "R". Casting numbers are 5741A for the front or 5310A for the rear. They are a solid cast front which I have not seen on other Case R tractors. Thanks for any Info.
The S would most likely be the only chance. The RC share rear wheels with the early SC.
I looked at some photos of a Case S and that's a match. Thanks for the help
<image src="http://forums.yesterdaystractors.com/photos/mvphoto8958.jpg"/>
You need to take a close look at photo . Look at the engine in that tractor it is R series tractor not a S.
My 1938 RC which I have had since the mid 60's has these flat spoke wheels.
The tractor on the trailer is a "R" the wheels on it are the ones I have for sale. This is the same "R" I put steel wheels on instead of the rubber.
<image src="http://forums.yesterdaystractors.com/photos/mvphoto8992.jpg"/>
