1959 Case 210B hydraulic bypass filter?
smc81c
New User
Hey all, I searched the forum and found the part numbers for the bypass filter I'm looking for. Which is the
Marvel Engineering Co. Bypass Filter Element
NSN: 4330-00-918-8077
P/N M-2032-135-35
I cannot for the life of me find one or cross reference it to another part on the internet.
Can anybody steer me in the right direction for a replacement filter?
my filter is crushed/collapsed from some other mister fix it prior to getting my fingers in it. The filter seems to be unobtainium.....i did get a quote from a place for 375$ for one filter.
I am just guessing you are talking the one on the loader hyd and not this one? If so I am sure I have a book on that as well but will have to dig a bit
cnt
Mine on my 310B hoe/loader is a mesh cleanable one. Mine was missing and I got a great one from our Knuk neighbor, Jean Claude Marleau, he monitors this and has an excellent stash of new and used parts
The original filter element was a cleanable edge wound type. It is in series with the oil return circuit not a bypass. They hole and/or collapse due to differential pressure when clogged or from system high back pressure.
The element is original Case p/n G13113. John Saeli sells the element. Also a suitable substitute disposable type element is Wix 51518.
Joe
http://www.wixfilters.com/Lookup/PartDetails.aspx?Part 76951
"The element is original Case p/n G13113. John Saeli sells the element. Also a suitable substitute disposable type element is Wix 51518."
Ooops, I was addressing the tractor internal hydraulic return oil filter shown in CNT pic. After reading the thread more closely, as I should have done in the first place, not sure what filter element you need.
Joe
it is the filter that is above the rectangular reservoir on the right side of the tractor. its a stainless mesh type filter that is cleanable. has a pipe tread on one end
that looks like the filter housing and filter. I think I may have tracked down a new part number D21008=C28783.
https://www.ebay.com/itm/Lube-Oil-Filter-for-Case-International-A36524-A39578-A51463-D32211-G13113/192245331216?hash=item2cc2b6f510:i:192245331216
Both these pics are from Case parts substitution manual dtd 1989. Generally it is the same part with just a p/n change.
1. Note that D21008 cross-ref to R2799. This is an old manual p/n's may have changed again.
2. C28783 just gives an outside source, does not state whether it is a filter or not.
3. Two C28783 filters listed available as CasIH parts at this link. You'll have to confirm it is the filter you need. I don't know how to order from this site, I think you may have to do it through a Case dealer. Anyway if you figure out how to order please post back the procedure.
Joe
http://parts.depotparts.com/Parts/Single/StartsWith/A/C28783/
This may have to be bought from a CE dealer as cih decided it was a good idea to make certain parts available only through a AG or a CE dealer
cnt
thanks for the info. I found a filter from a case dealer online. they list it as C28783. not cheap but they can be found if needed.
(quoted from post at 21:01:57 01/10/18) Both these pics are from Case parts substitution manual dtd 1989. Generally it is the same part with just a p/n change.
Joe
