John Achmann
I seen somewhere you had nos cylinder kits for an 18-32 cross motor at one time. I got new liners made and new sealing rings for the bottom. I was wondering if you happened to still have the kits if you could measure the size of the sealing rings. The ones I got from a antique gasket company seem little tall. With the liner in the block bore with the ring on it?ll have to crush the ring a little more then 1/4 of an inch. Don?t want to wreck anything putting this together. The bores are clean as I can drop them in all the way with out the sealing rings. New liners were made to the old ones I removed from the tractor. Any help will be appreciated . Thank you!
