Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
1959 Case 210B hydraulic bypass filter?
smc81c
01-09-2018 18:28:15
Hey all, I searched the forum and found the part numbers for the bypass filter I'm looking for. Which is the
Marvel Engineering Co. Bypass Filter Element
NSN: 4330-00-918-8077
P/N M-2032-135-35
I cannot for the life of me find one or cross reference it to another part on the internet.
Can anybody steer me in the right direction for a replacement filter?
smc81c
01-11-2018 15:46:55
 Re: 1959 Case 210B hydraulic bypass filter? in reply to smc81c, 01-09-2018 18:28:15
thanks for the info. I found a filter from a case dealer online. they list it as C28783. not cheap but they can be found if needed.
Case Nutty 1660
01-11-2018 03:51:24
This may have to be bought from a CE dealer as cih decided it was a good idea to make certain parts available only through a AG or a CE dealer cnt
Joe (Wa)
01-10-2018 20:01:57
Both these pics are from Case parts substitution manual dtd 1989. Generally it is the same part with just a p/n change.
1. Note that D21008 cross-ref to R2799. This is an old manual p/n's may have changed again. 2. C28783 just gives an outside source, does not state whether it is a filter or not.
3. Two C28783 filters listed available as CasIH parts at this link. You'll have to confirm it is the filter you need. I don't know how to order from this site, I think you may have to do it through a Case dealer. Anyway if you figure out how to order please post back the procedure.
Joe
Stephen Newell
01-10-2018 18:37:22
https://www.ebay.com/itm/Lube-Oil-Filter-for-Case-International-A36524-A39578-A51463-D32211-G13113/192245331216?hash=item2cc2b6f510:i:192245331216
smc81c
01-10-2018 17:57:16
still looking for a place to source a filter. any leads would be great.
smc81c
01-10-2018 15:07:18
that looks like the filter housing and filter. I think I may have tracked down a new part number D21008=C28783.
smc81c
01-10-2018 14:18:10
 Re: link to what im looking for from this sight in reply to smc81c, 01-09-2018 18:28:15
it is the filter that is above the rectangular reservoir on the right side of the tractor. its a stainless mesh type filter that is cleanable. has a pipe tread on one end
smc81c
01-10-2018 14:14:24
http://www.yesterdaystractors.com/case/messages/208332.html
Case Nutty 1660
01-10-2018 12:11:27
Or this one maybe
cnt
Joe (Wa)
01-10-2018 10:25:43
The original filter element was a cleanable edge wound type. It is in series with the oil return circuit not a bypass. They hole and/or collapse due to differential pressure when clogged or from system high back pressure.
The element is original Case p/n G13113. John Saeli sells the element. Also a suitable substitute disposable type element is Wix 51518.
Joe
Joe (Wa)
01-10-2018 11:36:17
 Re: 1959 Case 210B hydraulic bypass filter? in reply to Joe (Wa), 01-10-2018 10:25:43
"The element is original Case p/n G13113. John Saeli sells the element. Also a suitable substitute disposable type element is Wix 51518."
Ooops, I was addressing the tractor internal hydraulic return oil filter shown in CNT pic. After reading the thread more closely, as I should have done in the first place, not sure what filter element you need.
Joe
Stephen Newell
01-10-2018 05:19:25
There is a G13113 on ebay for 18.84.
Case Nutty 1660
01-10-2018 04:42:43
I am just guessing you are talking the one on the loader hyd and not this one? If so I am sure I have a book on that as well but will have to dig a bit
cnt
smc81c
01-09-2018 19:12:22
my filter is crushed/collapsed from some other mister fix it prior to getting my fingers in it. The filter seems to be unobtainium.....i did get a quote from a place for 375$ for one filter.
Stephen Newell
01-09-2018 18:59:35
I believe the one I have is a wire mesh. I just cleaned mine with lacquer thinner and blew it out with compressed air.
oldproudvet
01-10-2018 07:10:34
 Re: 1959 Case 210B hydraulic bypass filter? in reply to Stephen Newell, 01-09-2018 18:59:35
Mine on my 310B hoe/loader is a mesh cleanable one. Mine was missing and I got a great one from our Knuk neighbor, Jean Claude Marleau, he monitors this and has an excellent stash of new and used parts
