blueridge
- Location
- Crawfordsville In
Has anyone done a steering box overhaul off a 611B or another model with same setup? I & T Manuel says you have to take radiator off and plate under it to get top off gearbox? Seal and bearing out of worm shaft going to steering shaft. can't tell if top will lift off shaft to pull it off and clear radiator, If cannot get top to come off, gasket is shot and will have to pull radiator. just wondering if someone has done this project? Really hate to have to pull radiator and deal with Case-O-matic lines. but will if I have to I guess. Thanks for any help you can give. Gene
