930 vs 400 ring and pinion
930puller
New User
I have a 930 puller with a bad pinion and was wondering if the ring and pinion out of a 400 will bolt in. As I would like to use the faster pinion out of a 400 orchard.
It wont fit,its way to small,if you want to go faster you need an 1170-1175 ring and pinion,but they wont fit on your differential wheel. I have used 930 sets for $300.00 715-308-2163
Wont the 1170 high/low range gears give him
about a 1/2 gear change? I cant remember if
its up or down either.
