John Saeli
Feed mill called early this afternoon & wanted to load Triticale in about an hour. Bin is @ the other place, 4 miles from here. Wanted to use the 730 w/ Loader to run the auger so when we are all done, we are able to empty the hopper & dump it in the truck. Everything cleaned up. I get over there, sun is to the west, 730 in the lean-to on the East side, in the shade, temp is 16 degrees. I pulled the pick up alongside & hooked up the jumpers and let the truck top off the batteries while I got the auger ready. The 730 was not plugged in. After about 10 minutes, I jumped on the 730, ran the starter till smoke rolled out the exhaust, about 5 seconds. I then ran the manifold heater for 45 seconds, waited 10 seconds, hit the starter & she started.
Why?? Because I did the valve job some years ago & did not grind valve or seats, I replaced them.
