Boilermaker128
New User
Hi all,
New to the forum, looking for some help with my 1958? 310 case. I bought to use a blower on my lane way. Went over tractor when I bought it, installed a new seat, changed the oil, adjusted the valves, repaired the air filter, put new plugs in, put a new coil on, greased 1000 nipples, put a new set of tires on the back, getting her geared up for winter blowing.
Got some fresh snow yesterday and fired her up. Blower works great, hydraulics work good and clutch works good too. I am having an issue with it popping out of gear in reverse however. it will stay in gear if I hold my hand on the lever or my leg when I'm turned around looing at my travel path. I feel this will be a large PIA if I have to constantly keep pressure on the lever when blowing as that is what I mainly do with the tractor.
Is this a common issue?
easy/hard fix?
I took off the cover to the gear box. the cover comes off with the shift lever attached along with 3 shift selectors. everything seems to work smoothly, and I don't see anything bent (to my knowledge) Looking at the gears, as few look to be ground on one side. Is this my issue?
First tractor, so need help to identify the problem.
thanks for any suggestions in advance.
easy/hard fix?
