Case combines...
casecollectorsc
Location
E central SD.
Put some pictures on the combine forum, might as well put them here also....
Always good to see the machines.Is the Jd feeder housing from a 105? I have a 1160 that I want to get a feeder house for.Does the feeder house from a 95 fit the 1160 with a little shimming? Thanks
On your 1660 did you widen the feeder housing or did you make a spacer? I didn't see a spacer in the pictures you posted but then wasn't sure.Thanks
