Case 310c brake bands
CathyCase
Hi, does anyone know a source for the case 310c brake/sterring bands. All kindsof places sell the ones for the 310
Thanks
(quoted from post at 05:34:08 11/29/17) Hi, does anyone know a source for the case 310c brake/sterring bands. All kindsof places sell the ones for the 310
Thanks
I couldn't find a listing for a 310C in the online parts manual. You should give external_link a call at 315-585-9826. They stock the parts for older Case tractors.
i did that, there are lots of sources for 310 brakes , but when Icontacted them they said those will not fit a 310c
Thanks, I want to take a look at the brakes before I order. I plan to do thTthis weekend. If I need a set I will contact you. They may just be out of adjustment
You do have to make sure you use mineral oil in your brakes. There actually steering bands as there is not steering clutch. When you pull one side it will not completely stop that side , just slow it down a lot. I have a 310c myself and a parts machine. mine has the loader on it. You do have to look for the 310 dozer/crawler. I think they do make a tractor but it will not be the same.
Thanks. I understand that there is no clutch on the steering. This 310c was purchased new by my grandfather, I drove it up until about 1985 on our family ranch. My parents sold our ranch in 1985 The crawler went with the place. I recently got the case back and it needs lots of work. In the past I replaced the bands, probably about 1972.
