VCMB 2 Btm Plow
Just looked at this Plow, has both colters, moldboard
scrapers, trash rods, and adjustable tail wheel. Never saw
this model with all these accessories. Worth ?? Hoping to put
it on my 48' VAC. Thanks, Mike
Does it have all off the lift hardware? The lift frames are not all the same width. I was going to put a plow I had on a tractor with the lifting hardware and it was not the same width. I think it depends on the width of the bottoms.
As far as value it's worth what ever you are willing to give. I have a few things around here that I can't get my money back on. These plows don't have a high resale value.
Pics would help. I would guess 100 and up depending on condition and how bad you want it. Good Luck, sounds like a nice one. Nick
Hi Nick, it's mounted on a 47' VAO. ALL the hardware, lifting mechanism, plus correct VAO lifting arms are included. Looks Identical to the system I have now. Rear ends should be the same on the VAC and VAO right ??
My rule of thumb to figure value of an old plow is to figure $100 per bottom and then add or subtract for excessive wear or presence of desirable features. Oddly, a small plow will often sell in the higher cost range while larger and newer plows (harder to haul, move and store) will bring less.
My two sons and I collectively own about 25 CASE plows, enough for our own family plow day. Last time took 1 !/2 days to get 5 tractor/plow combinations ready to plow about 4 hours.
