70 series lighting
I'm hooking up the flashers on my 770. The flashers work
with the third setting on the light switch only. The front lights
shut off on the third setting which seems odd. Is that the way
they are supposed to work? I would expect the front lights to
stay on or the flashers to work on another setting for driving
on the road at night.
Must have the wrong wires plugged in at the lights. I assume you are talking about the fender lights aiming ahead. There should be 2 sets of wires there for 2 lights on each side. The one set turns off when the road lights are on so they are not so bright for oncoming traffic. The other set should stay on. If that is not the problem start testing on the switch. Might be something wrong with the switch.
Do some digging in there for a second wire. My 870 has 2 wires to each side with a second light mounted above the fender on each side.
