I have a case 480b everything works good.i checked the transmission and it's low can anyone tell me what kind I need to use and how much. I see two(2) places on top of shifter is that the only places to fill. I don't have a service manual. Thanks for any help on thin matter
plug on the trans housing almost under the seat is for the rear axle /transmission, 90 wt recommended
plug towards the pedals is for the shuttle/torque tube Hy-Tran recommended but any good quality equivalent can also be used
cnt
90 weight gear oil is still around, but EP85W-90 (or 80W-90) is more common now. EP85W-140 is another option, but will be thicker. NAPA and other parts stores should have choices. This is would be GL4 gear oil not GL1 90 mineral oil like Fords use.
