TractorLinks.com
Show Parts for Model:
Finally got some corn out
Jon f mn
11-13-2017 12:31:58
Finally got everything working and got out a semi load of corn yesterday. Was warm enough that the frost was coming out so I had to deal with mud in a few spots, but not enough to get stuck. Supposed to be warm alk week and rain tomorroow again so that will likely be all for a while again. Going to get cold next weekend, but maybe more snow. Would be nice if it just got cold and stayed that way for a while. Lol.
Ande
11-15-2017 05:07:39
 Re: Finally got some corn out in reply to Jon f mn, 11-13-2017 12:31:58
Jon, did the mouse family move out of the cab
Jon f mn
11-15-2017 10:23:01
 Re: Finally got some corn out in reply to Ande, 11-15-2017 05:07:39
Sadly they ate something that didn't agree with them and they perished. Had a couple families of hornets move in tho, luckily it was cold when we discussed living arrangements and they were easily evicted.
Ande
11-15-2017 19:32:22
 Re: Finally got some corn out in reply to Jon f mn, 11-15-2017 10:23:01
Hehe, just remember last year when you took a pic of your rider with you
ed will
11-14-2017 09:36:11
Hi, I never had anything to do with combines because we never grew grain. But I used to run a gravel crusher. I used to crawl between the screens to undo the bolts that held the screen down in order to change sizes. Other wise you would need to take a few layers out to get at the ones below. Your post reminded me of that some 40+ years ago. Ed Will Oliver BC
1370rod
11-13-2017 18:15:38
Good to hear you are able to get some corn out Jon. The sample in the tank looks good, what kind of moisture does the corn have? Rod.
Jon f mn
11-13-2017 18:35:43
 Re: Finally got some corn out in reply to 1370rod, 11-13-2017 18:15:38
Don't have a tested so we won't know til Jeff gets it to town, but I'm guessing 18% or so.
Adirondack case guy
11-13-2017 16:58:19
It looks like you got the lifter fingers bolted back onto the back of the concaves, How many puncture wounds do you have in your belly from crawling over the racks to get it reattached ???? I spent a lot of time inside Case combines and had an old drapper belt from a Case 850 swather that I rolled out on the sieves to cushion me when crawling inside them.
Loren
Jon f mn
11-13-2017 18:34:17
 Re: Finally got some corn out in reply to Adirondack case guy, 11-13-2017 16:58:19
As per Tom's instructions, and the reason he's on "the list", I took the head off and pulled the concave out.
Don Rudolph
11-13-2017 16:13:37
Jon,
I sure admire your tenacity keeping that old 1160 going. Do you have the Chrysler 318 or Case diesel engine? Don
Jon f mn
11-13-2017 18:32:07
 Re: Finally got some corn out in reply to Don Rudolph, 11-13-2017 16:13:37
It has the 318 chrysler.
vac400
11-13-2017 14:33:24
Jon, Great pictures, and clean corn , you must have it set to perfection. Wet here and I just finished corn , nothing to brag about. Jerry from Ohio
2510Paul
11-13-2017 13:43:19
Thanks for taking the time to take and post the pictures. What is the model of that combine? Paul
Jon f mn
11-13-2017 14:56:00
 Re: Finally got some corn out in reply to 2510Paul, 11-13-2017 13:43:19
That is an 1160 special.
Chuck Machinist
11-13-2017 16:03:16
 Re: Finally got some corn out in reply to Jon f mn, 11-13-2017 14:56:00
How may acres will you be putting up Jon?CM
Jon f mn
11-13-2017 18:37:18
 Re: Finally got some corn out in reply to Chuck Machinist, 11-13-2017 16:03:16
Not sure exactly, but 50-60 this year. That's enough til I get all the bugs out of it.
Chuck Machinist
11-14-2017 01:50:02
 Re: Finally got some corn out in reply to Jon f mn, 11-13-2017 18:37:18
You going to do POTATOES next year!? HEE HEE.CM
