TractorLinks.com
Show Parts for Model:
Gear oil question
Crl800
11-12-2017 14:32:20
Can someone tell me what type of oil goes I a 400 case rear end/ trans? They are together, correct? And maybe how many gallons? Thank you in advance. Carl.
Crl800
11-15-2017 04:08:32
 Re: Gear oil question in reply to Crl800, 11-12-2017 14:32:20
Thanks for the information guys. I got it drained and didn't spill any.
L.Fure
11-12-2017 17:57:04
A lot of clean concrete garage floors have nearly been ruined because of the plug getting away from the person doing the draining. Plugging the transmission breathers will slow the flow some. You might be able to switch buckets between the glurks and not spill as much oil.
Chuck Machinist
11-12-2017 15:40:56
85/140 is what you use,and 14 gallons is what is recommended .I also caution that when you drain the transmission that you remove the plug just rear of the front plug. Also ,and I beat this dog to death,but once you remove the plug,make sure that you have three 5 gallon pails ready to catch the product. Place a piece of plywood under the buckets, as it allows the buckets to slide easier as you slide the next bucket in place. You will never be able to re install the plug until it drains.just sayin. Been there ,done that.CM
casecollectorsc
11-12-2017 15:28:57
The manual says 90 weight...15 gallons.
Hydraulic system...hy-tran, 10.5 qts. with Eagle Hitch.
Crl800
11-12-2017 15:31:53
 Re: Gear oil question in reply to casecollectorsc, 11-12-2017 15:28:57
Awesome. thank you.
John Saeli
11-13-2017 05:06:37
 Re: Gear oil question in reply to Crl800, 11-12-2017 15:31:53
The Manual says 90 gear oil, but 85W140 was not available at that time. However, 85W140 is a much better choice, it offers the "lubricity" of an 85 weight when cold, but the protection & lubricity of a 140 when warm.
