Earlier I had posted about a problem with the PTO shift lever. The lever is positioned to the left rather than to the right like it should be. In order to engage the PTO I have to push the lever down instead of pulling it up. A member on this board wrote that the roll pin that engages with the shift fork (G10677) probably had went too far and ended up on the wrong side. By looking at the parts break down it looks like all I needed to do was to pull the shift shaft (G10452) towards the rear and turn it to the tight to reposition the roll pin. I tried that with no success. Now I'm thinking about removing the Welch plug (VT3399) on the right side of the PTO housing to gain access to the shift fork. If I'm lucky I might be able to pry the shift fork rearward, turn the shift shaft to right to reposition the roll pin. Wish me luck.
