1968 case 1030 foot cluch sticking
daynee
I have a 1968 case 1030 that's always been in the family since the 1980's it's cluch has been sticking so bad that I have to kick the peddle just to disengage it ! Also the same thing with it coming back to engage kick it back, when its engaged the tractor will tow anything ,no slipping . The springs look okay from the inspection hole also grease for the shaft inside.
Thank you for reading
Dayne
The pedal its self is dry and sticking in the pivot, seen this before work some Oil into it from both sides while working the pedal, you can check this by pulling a pin in the linkage
cnt
