Stephen Newell
I've had problems with the starter on my 210B turning the engine over fast enough to start the tractor. I finally burned up the starter. I replaced the starter and it's doing the same thing. Then the starter solenoid fused up to where it wouldn't disconnect so I replaced the solenoid with a heavy duty one. The starter still doesn't turn fast enough unless I remove all four spark plugs. There isn't a problem with the ground or cables and I've tried to start it connected to two batteries. Don't know what else to try. If it didn't have the front loader sitting on the ground I could maybe have a wrecker take it to a mechanic but I can't really afford that right now.
