Bobbynj66
New User
Can and steer me in the right direction I'm looking for a new,used or rebuilt distributor for my 580ck it's a
Auto-Lite #IBT-4403A any help is appreciated I cant find anywhere
Or maybe im posting this the wrong section if theres somewhere else I can post for better feedback I appreciate the input thanks.
You're posting in the correct place, problem is CASE does not offer any internal parts for that distributor, (bushings, shaft, ect.) nor does anyone else. If you search the internet, there are a few re-builders
(quoted from post at 12:32:56 10/13/17) You're posting in the correct place, problem is CASE does not offer any internal parts for that distributor, (bushings, shaft, ect.) nor does anyone else. If you search the internet, there are a few re-builders
Hows about the whole distributor new? Or maybe a cross over number? Thanks
I went to install a ignition kit today and one of the springs under the plate was mangled and the other disconnected and I have no clue where they go. Its also very sloppy so was going to replace rather than mess with it.
I have a new never run distributor for your tractor. The number on mine is IBT 4403 B. Your part number has an A at the end where mine has the B. Mine also has provision for a tach drive so if your tach drives off your alternator or generator that may be the difference. Either way it will work on your tractor.
