TSX 114 Carbureator Air Adjusting Screw
Have a question concerning the air adjustment, my service books don't tell me how many turns out to initially set up the carb, I currently have it set at 2 turns out, and the Main Jet at 1 1/2 turns out. Idle screw is set at 3 turns out with tractor at idle speed for now.
Thanks, Mike
My 48' VAC tractor. I wasn't able to find anything in my operator's or service manuals, they are originals printed in 3-48.
Thanks, Mike
Mike, the idle screw may be a bit far out but it should start at those settings no problem, if you like give me a call I can walk you through how I fine tune them, if you need help there
cnt
Air adjusting idle screw richens mixture as you screw it in CW. Start about one turn off the seat. Normally I end up 1/2 to 1/4 turn off the seat.
Joe.
