530 going back together
dacaseguy
Finally got my 159 engine back together. Bought this 530 in a basket case you might say. Head and pan was off, and Pistons were stuck bad. Had to turn crank to 10 under to clean it up. New sleeves and Pistons from John and Cris, redone head with new valves. Had to find a on or rod and had all 4 rods redone and sized at machine shop. Tractor has good rubber and it came with a case loader. Rebuilt the seat, just need cushions, and got a new steering wheel. Should be pretty nice when I get her finished. Dick
Chuck, I use rusntolium primer. It as allwYs worked for me. The sheet metal has two coats. This is not a show tractor, just trying to make her
purty. Dick
Chuck, I use rusntolium primer. It as allwYs worked for me. The sheet metal has two coats. This is not a show tractor, just trying to make her purty. Dick
