68 case 580 starting problems
Twn
New User
I have a68 case 580 ck have spark and fuel just having trouble starting it seems that at times the compression builds up and it starts easy. Having a problem thou getting compression all the time. Is there a way that I can help it to get compression when it isn't giving any. Please help thanks
sounds to me like you have a carb fuel level issue, do you shut the gas off when you park it? if your carb float is allowing too much gas in it can make starting like you describe, I see no way you can lose compression only when starting, if you had valves sticking it would do it running
cnt
(quoted from post at 05:46:09 09/29/17) I have a68 case 580 ck have spark and fuel just having trouble starting it seems that at times the compression builds up and it starts easy. Having a problem thou getting compression all the time. Is there a way that I can help it to get compression when it isn't giving any. Please help thanks
I don't know how your compression can change from one time to another. Is the starting problem something that just cropped up recently, or did you do something to the tractor, and this problem showed up after that? We need more information in order to figure this thing out.
it had almost always done it. It really happens after the filter gets clogged and the tractor will shut off. I clean the filter out and then it has a really really hard time starting. It has fuel getting to it
(quoted from post at 16:22:40 09/29/17) it had almost always done it. It really happens after the filter gets clogged and the tractor will shut off. I clean the filter out and then it has a really really hard time starting. It has fuel getting to it
What filter are you cleaning? Are you cleaning the screen in the sediment bowl?
