I looked a 611B that is for sale. Before we started the engine the owner told me about the engine knock. I wish he had mentioned that in the add. Anyway, here is the explanation he had. He said that there was a hole in the exhaust manifold at the number one cylinder that he welded shut. It was after that the knock showed up. At first he thought some slag ended up on the piston top. He checked it with a plumbers camera, and there was nothing there. So he concluded that some welding beads and slag got stuck under the exhaust valve causing it to not close all the way. The knocking is the huge tappet clearance when the valve doesn't close all the way. Does that sound feasible? The knock does sounds like it's right in that area. Should I buy it and figure on removing the head and replacing one valve and one valve seat?
