1953 DC , foot clutch spring, belt pulley
Dustyah
Does anyone one know where I could buy a foot clutch spring, for a foot clutch DC and a resilient belt pulley for the same DC , also remote hose bracket clamps, to hold hoses to bracket, some one offered but I forgot whom, thanks dusty
I don't think you will find the Foot Clutch Pedal Spring anywhere. It was a unique design because not only did it return the pedal, but also assisted in depressing. The solution is to find a heavy spring & use a hook & eye from the hardware store. Most hardware stores will have a spring selection. Don't have a pulley, but we do stock the hose brackets.
I should have been more specific on the spring. A simple spring, hook on each end, and an Eye Bolt, threaded w/ a nut for adjustment. Difficulty will be getting the spring length & heft correct.
John if you have the hoops for the remote bracket to hose, I will have to get a set, do You also have an intake tube, the long tall guy, mines bent, do I need to order from your site, Dusty
