Black Knight
Can this line which is about a foot of rubber hose pressed onto a steel line to the valve be replaced with all rubber
hose? Second question can you take loose the back two cab mounts and jack up the back of the cab a few inches
so you can work underneath the cab is that even possible or just a bad idea . A couple of more inches of clearance
underneath that cab would make this job a lot easier to replace with original line. Thanks.
