Case CO Orchard Tin
bobinmi.
Looking for information, prints, parts, pieces, people that have restored Case CO. Any information may be helpful. Would like to make up the orchard tin and doing the research.
Thanks, Bob.
s,mac will be along shortly ,and lend an ear. What your going to find with the tin,fenders and cowl, is you will not find any straight or barn finds. if your real lucky, someone may let you copy their tin. But your going to be hard pressed ,again to find much,if not any at all. .Best of luck. CM Welcome to the forum!
I believe there was a CO with tin at the Albert City Ia. show this year. A youtube video that is up may give you some ideas. Also any one with possible advertising literature may also give you some visual perspective of the angles, intersecting angle points so you can duplicate. just a thought. gobble
s,mac
Sent you an email.
Just to give you guys a little back ground. We make fenders and other sheet metal pieces for tractor made from 1900 -1940, unstyled as we call them. We have patterns and original parts to work from. We do not do the clam shell or stamped type fenders. We are starting into gas tanks and other sheet metal items, have questions give us a call, see us in the classifieds , Fenders
We use the Forums to research the tractors and the parts from those that have or know of the model we are looking for.
Thank all of you for the help, it is your help that allows us to make a better and more accurate part.
Thanks again, Bob
