Can't find Air Cleaner Elements on 1490
ratface
Recently did some mowing of very dry grass and it occurred to me that I might want to check the air filtration on the tractor. Got the manual out which is publication 9-9323. Page 144 shows a very nice picture of the Air Cleaner Elements. They seem to be about the size of an oil filter and each one is two parts with a safety element installed within the main element. Problem is it doesn't tell you where they are located. Raised the hood and looked on both sides of the engine and don't see anything resembling these cartridges. Where are they hiding them?
the air cleaner is in front of the radiator under the hood of tractor. The can it is in is about 10" in diameter, 16" long, much bigger than an oil filter.
