580K injector pump?????
Need to know what engine/pump you have. If it's the Cummins there's a nut on the pump shaft that needs removed, then a plate is used to push the tapered shaft out of the drive gear.
I am "assuming" its a cummings because it had the nut on the shaft.. I got it out & was going to rebuild it but the rear shaft is broken. any idea where to get a pump ??
List the pump model number, may have the parts to repair it. If the shaft drive tang is broken sounds like the Case 188 or 207 engine, not Cummins. No mater what pump the cause of damage should be found so it does not happen again..
