karl h
I was baling hay last night, with remote engaged in rear position in 2nd powershift i can hear fluid under the right console and when i shift to third the fluid sound is still there and i also get the trans pressure light. The tractor operates normal in 1st powershift. Ant ideas?
yes it all works normal and when i downshift back to 2nd it goes out but i can still hear the fluid bypassing something under the consul
I talked to the dealer this morning he believes internal leakage from the clutch packs....talked like $6-10k to repair depending what they find when they split it. I don't think the tractor is worth much more than that...it's MFWD 9k hours needs duals and front tires....your thoughts?
