1960-61 Case 530: Gas, 12v, positive ground
Hello, I have some more questions regarding alternator conversions. I was reading through past posts and got some good info. With some help I determined that my generator is bad. When grounding the field and checking the arm. at high RPMs, the generator was turning and putting out .5v or something similar. Surprisingly, I cannot find any gen/alt repair shops around. Considering the price, an alternator seems like a good solution.
I will probably use the Delco 10si (one wire) as that seems pretty common, cheap, and sold locally at NAPA. I will lose the tach, but my tach was already not working (haven't taken the time to troubleshoot that yet anyhow). I have read that there were some different alternators that had a tach drive that would work.
When I install an alternator, I will need to switch to negative ground. Is there anything on the tractor that is polarity sensitive? Since I will lose the VR and generator, do I just install the alternator and swap battery cables?
Are there any new alternators with tach support commercially available? (for under $100)
If I install a Delco 10si (internally regulated), do I just take out the current voltage regulator and run the alternators single wire to the ammeter?
Any advice or recommendations on mounting the alternator? Is it pretty straightforward with a universal bracket?
Thank you for the help. I am still in the learning and trial/error phase.
