580b lost revers oil and filters good screen had no dirt
thought someone would comment,, if you are holding clutch psi when in rev, i would say you have the REV clutch discs ect are worn out, Always let these units warm up a bit before using them the first time for the day if you don't already, in the cold temps I let mine run 10-20 min before I ever use it, when you do a rebuild also make sure and replace all seals and worn parts and it will last many thousands of hrs again
cnt
(quoted from post at 05:51:59 08/18/17) thought someone would comment,, if you are holding clutch psi when in rev, i would say you have the REV clutch discs ect are worn out, Always let these units warm up a bit before using them the first time for the day if you don't already, in the cold temps I let mine run 10-20 min before I ever use it, when you do a rebuild also make sure and replace all seals and worn parts and it will last many thousands of hrs again
cnt
I checked the PSI @ the front trans filter housing and only getting 100 psi, manual says possibly the pump or relief vale, but can understand why it would move in forward with 100psi and not in reveres. I removed the spool valve body and all looked ok. Is it worth pulling the pump to check it or would it be better just to split the unit? When I removed the shuttle cover the shuttle looked ok (best I can tell)
Thanks for any help
