Eagle hitch plowing at Albert City
StanIowa
There were 18 tractors with 48 bottoms. I will call this a record and challange all future Case shows to beat this. Thank you to all that had a tractor and plow there on saturday. thanks Stan
Stan it was a sight to see and fun to participate, thank you for your work of organizing. Indeed now to see others try to better that performance will be fun. Rod.
On the video below of the plowing I only count 17 tractors and 43 bottoms and I've counted it about ten times. Are you sure of the count
I believe there is another tractor farther back that was still on its way before the video ended. That would mean one final tractor with a 5 bottom? The larger plows were towards the rear I believe.
(quoted from post at 03:19:02 08/17/17) I believe there is another tractor farther back that was still on its way before the video ended. That would mean one final tractor with a 5 bottom? The larger plows were towards the rear I believe.
Was that not Ross'es 400 Super with the 5-14's in the rear?
