I'm having some trouble with the clutch on my CK. When I try to start it, I hear a clashing noise the first few times. Then it starts. However, when I try to put it in gear, with the clutch pedal pushed down, I get more gear clashing, then it drops into place. Pressure won't stay in the green zone on the gauge. When I use the shuttle and swing from Forward to Reverse, the pressure drops.
Although the dipstick said the torque converter had enough fluid, I dumped in some more, the tractor started without clashing, but only twice. I also replaced the filter in front of the radiator.
Someone suggested I check the torque converter fluid to see if it had water in it. To do that, they said to drain off a little fluid and see how it looked.
The owner's manual shows three different drain points -
[list:4b069ce9a8]torque tube drain
torque converter housing drain
torque converter drain[/list:u:4b069ce9a8]
Which one is correct?
If I drain from one or all of them, do I use the torque tube dipstick to refill them all? (nothing else mentioned in the diagram)
What's a good source for service manuals?
Thank you in advance,
Scott
P.S. I had posted this in the general tractor discussion, olgentdc suggested this would be a better place to ask Case specific questions.
Scott
