1030 Factory Cab Floor Mat and Headliner
1370rod
Had a customer request these two items. Anyone know if they are still available anywhere? Or do we make our own, Rod.
Rod, I'm in the process of making my own floor mat and head liner for my 931. The original head liner was made from perforated Masonite with an inch of fiberglass insulation in between the ribbed struts in the roof and had a chrome strip crossways, screwed in the center strut to hold up the front and back pieces Masonite. I am cutting 1" thick cab padding that I bought from Speer Cushion, and fitting it to the struts, hoping to deaden the noise in the cab. I bought some diamond plate design foam floor mat from Runnings to make the floor mat from.
Loren
Can't help you Rod, but I have used sound absorbing foam mat from McMaster Carr as an underlayment on older tractors (IH966, 1466 and Case 1170 & 2590). The 1" thick stuff is 54" wide and about $20/foot of length. Cuts a lot of the harsh noise at a reasonable cost.
You can check with Fehr cab interior here in IL, but I think they only go back to the 70 series with stock pre-made kits. If you had remains of both pieces they will/can also custom make interiors as well. Fehrcab.com 815-sixninetwo-3355 a good family run business and product.
Brad
I've always wondered if there isn't somebody from Allen Industries alive today who can say who their suppliers were so they could be tracked down. If it was produced once before, it should be able to be produced again (for a price). I have three cab tractors that I'd like to replace the headliner and floor with original material. I'm sure I'm not the only one. Another item I'd like to find is the original dome light fixture.
