VAC Hydraulic pump seal
Does anyone have the part number for the hydraulic pump seal and gasket for a VAC? I am told the seal is readily available from NAPA, but I don't have parts book to get the number.... THANK YOU!
The original seal p/n was O4244AB (first character is letter O, not digit zero) That p/n was changed to A26778. Look up A26778 at the FM link crosses to National p/n 471466. Check the specifications down page.
You can cross 471466 at CR (2nd link) and cross to CR seal 4604. That is the seal that Napa will probably give you.
The body gasket original p/n was V20403 changed to A30760. Probably not available from Case. Measure thickness and buy bulk gasket and make your own.
Mounting gasket is common 1/32" thickness. Buy bulk gasket material any auto store and make one up.
http://www.fme-cat.com/
http://www2.chicago-rawhide.com/popup_parts_lookup_457012.htm
Joe
