400 vs 700 ground speeds
EP
Can anyone give me the ground speeds for these 2 models? I'm thinking about swapping the range gears from a 700 into a 400. The tooth count is different plus the 700 has bevel gears vs straight on the 400. Thanks
400 Racine?
So that I don't misquote you on the question that you're asking which one is it 400 B or 400 Racine? my picture is a 400 Racine.CM
Search for the Nebraska test for both models. It will give you the speeds at rated rpms for each gear and the tire size used in the test. Be sure to take that into account. You also may find the tooth counts of the gears in the Case parts books online.
701 1st 1.4 _________________ 401 1st 1.36
2nd 1.9 _____________________ 2nd 1.94
3rd 2.7 _____________________ 3rd 2.66
4th 3.8 _____________________ 4th 3.85
5th 4.8 _____________________ 5th 4.84
6th 6.9 ______________________ 6th 6.89
7th 9.4 ______________________ 7th 9.44
8th 13.7 _______________________ 8th 13.66
1525 rpms 1500 rpms
